作者:音魂不散 阅读数:6968 发布日期:2013-03-14
DYNAUDIO丹拿全新Evidence Platinum证据铂金版扬声器,在丹麦斯坎讷堡的丹拿工厂以最高标准打造,采用最先进的单元、精挑细选的分频元件,以及最高品质的全新分频器,包括采用4个全新的18W75低音单元代替以往的17cm低音单元,令低频表现更显优异,配合Esotar2高音单元和全新15cm MSP中音单元,以无与伦比的纯净音色和宏大而精细的音场,把扬声器的性能推至全新高度。证据铂金版采用了丹拿创新的DDC(丹拿声音扩散控制)技术,有效减少房间反射影响,保持声音原貌。箱体内部采用了立体加强设计,配合超坚固的40mm的黑色铝质前障板,实现良好的声学工作调教、以及特别设计的加固宽体箱体底板,让Evidence Platinum整体稳定性更高。
DYNAUDIO丹拿全新Evidence Platinum证据铂金版旗舰扬声器,在2012年中的时候在德国慕尼黑音响展的时候以概念产品的形式与发烧友见面,而正式推出市场的时间是2012年秋季,Evidence Platinum证据铂金版在丹拿旗舰大证据和小证据的基础上加以改进,融入了丹拿在创造至尊终极版以及信心签名版时取得的技术和经验。
Features
Evidence Platinum Esotar² tweeters with Precision Coating
Evidence Platinum 15cm MSP midrange drivers
Evidence Platinum 18cm MSP woofers (18W75)
Highest-grade Crossover with select components on glassfibre-reinforced PCB
WBT NextGenTM Cu connectors made of pure, gold-plated copper
Internal wiring with select oxygene-free copper cables
Metal Film resistors in the crossovers tweeter section
Advanced DDC Technology to reduce room reflections and colorations
Ultra-solid, resonance-deadening 40mm black aluminium front baffle
Reinforced cabinet finished in a new choice of veneers and lacquers
Reinforced base plinth with larger footprint for improved stability
Two types of base plinth feet included (for hard floor or carpet)
Technical Specifications
Sensitivity
89 dB
Recommended min. Amp. Power
Listening distance:
3 m:
20 watts (4 ohm)
5 m:
60 watts (4 ohm)
7 m:
120 watts (4 ohm)
10 m:
250 watts (4 ohm)
IEC Power handling
550 W
Impedance
4 Ω
Frequency Range
28 Hz – 25 kHz (± 3 dB)
Bass Principle
Bass-Reflex, rear-ported
Bass Port Resonance Frequency
27 Hz
Crossover slope
6dB/octave
Weight
115.0 kg / 253.5 lbs
Dimensions (W x H x D)
210/390 × 1940 × 510 mm
(8.3/15.4 × 76.4 × 20.1 in)
